NI TestStand Idea Exchange
mwatkins
TestStand - Step Error - More info cannot be copied to clipboard
Status: New
When TestStand has a problem with a module, it provides a Red Exclamation mark to show detail on the problem.
When you hove over the Red Exclamation mark, you get the details, sometimes with a file path to the detailed error log.
Need a way to copy/paste the data from the details bubble. Better would be a hyperlink to the file location.
Right now my workaround is:
 - Screen capture while hovering over the red exclamation mark
 - Paste the screen capture in MS Paint
 - Re arrange the windows to show MS Paint & MS Explorer
  - Navigate down file path to find the log file.
Sr Test Engineer at American Innovations - LabVIEW CLA - Kudo's are appreciated!!
1 Comment
bienieck
Been there, done that. Current solution is ridiculous.
Could be at least e.g. "Ctrl+ClickOnIcon" to copy this message to the clipboard or something like this.
Michał Bieńkowski
CLA, CTA
Someone devote his time to help solve your problem? Appreciate it and give kudos. Problem solved? Accept as a solution so that others can find it faster in the future.
Make a contribution to the development of TestStand - vote on TestStand Idea Exchange.
