User | Kudos |
2 | |
2 | |
1 | |
1 | |
1 |
We have multiple sequences in a file to perform steps that are common to particular subsystems. It would be nice to have the ability to group sequences within TestStand. I could envision this to look like a treeview or folder/file structure within the Sequence Pane. Currently, we have to use a common naming convention to group the sequences together like below:
GPIO_Inputs_[Seq1]
GPIO_Outputs_[Seq1]
GPIO_Outputs_[Seq2]
Communications_CAN_[Seq1]
Communications_Ethernet_[Seq1]
Communications_Ethernet_[Seq2]
Communications_UART_Port0_[Seq1]
Communications_UART_Port1_[Seq1]
Communications_UART_Port1_[Seq2]
With grouping, it could look similar to below:
Communications
CAN
[Seq1]
Ethernet
[Seq1]
[Seq2]
UART
Port0
[Seq1]
Port1
[Seq1]
[Seq2]
GPIO
Inputs
[Seq1]
Outputs
[Seq1]
[Seq2]
In addition, there could be a toolbar menu item to switch between showing the grouping or all so you could sort to find
