NI TestStand Idea Exchange
Sam_Sharp
TestStand Expression Macros
Status: Duplicate
I'm closing this and adding a link to this description in the other post.
https://forums.ni.com/t5/NI-TestStand-Idea-Exchange/Expression-Variables/idi-p/2678825
Let's say I'm building a fairly long compound expression that has some repeated parameters - I would like a way to specify (without creating additional locals) a variable/macro for use just within that expression.
For example, instead of:
Locals.CommandLine = "cmd /c C:\some path\that\is\reused"
Locals.CommandLine += " /path C:\some path\that\is\reused"
I could specify:
#pathmacro "C:\some path\that\is\reused"
Locals.CommandLine = "cmd /c " + pathmacro
Locals.CommandLine += " /path " + pathmacro
The idea being that with this I only need to update the macros in one place in a long expression.
This is a simple example, but hopefully you can see why this would be useful and why I wouldn't want to create lots of locals when the values are required only within the expression.
(blog)
3 Comments
paulmw
RustyStrings
I believe that I suggested that TestStand use macros many years ago.
Or it may have been to define constants that could be used for things like hardware addresses
I think a define statement would be great.
instead of:
Locals.UUT = RunState.TestSockets.MyIndex+1
have something like this in a special macro sequence (or anywhere for that matter)
#DEFINE UUT = RunState.TestSockets.MyIndex+1
Even if you need to prefix with a special character like ~
~UUT = RunState.TestSockets.MyIndex+1
then you could just use ~UUT for RunState.TestSockets.MyIndex+1
I dislike having to use variables for data that doesn't change
Perhaps it is just beyond the capabilities of TestStand
WireWeaver
Status changed to: Duplicate
