NI TestStand Idea Exchange
dshao
Test TamTam plugin to support TortoiseSVN integration with TestStand
Status: Declined
Declining due to lack of community support.
TortoiseSVN is an easy to use Source Code Control tool. However, it needs a MSSCC API plugin in order to be integrated with TestStand. On NI web page, PushOK is listed as a tested plugin with TortoiseSVN by NI tech team. PushOK is made by a Russian company. Another AgentSVN plugin is made by an Australia company. From an end user perspective, the time zone difference will cause some difficulty to access tech support in case it is needed. I used TamTamSVN 1.4.9 plugin for TortoiseSVN integration with TestStand and it worked fine. TamTamSVN plugin is made by an US company located near NYC area. I will suggest NI Tech team to test TamTamSVN plugin for TortoiseSVN integration with TestStand to ensure its features and functionality are acceptable to NI applications. If it pass the test, please add it into tested list.
1 Comment
HarshaBhushan
Status changed to: Declined
