NI TestStand Idea Exchange
JV_Psi
Support milliseconds logging to SQL database column with datetime format.
Status: New
The suggestion is to support logging a datetime with millisecond accuracy to an sql database with an NI_DataOperation step.
I tried to implement this, but the milliseconds are not written to the database.
It would be very usefull to support this feature.
The datetime field in the sql database is defined as follows:
CREATE TABLE
dbo.UUT_RESULTS (
UUT_STARTTIME datetime NOT NULL
The datetime is logged to the database, but only up to the seconds, although the format string is defined as "mm-dd-yyyy hh:ii:ss.sss" and the string does contain the milliseconds e.g. "2-10-2016 11:49:15.505".
Software Details: TestStand  version 2010 SP1, Operating System:  Windows 7
3 Comments
RikWel
I experience the same issue in TestStand 2017 SP1. Windows 10
Michael_Volk
Same here, also Teststand 2017 and Windows 10..
RavensFan
Knight of NI
Well Michael.
If you have the same issue.  Then you should click the Kudo star to register your vote for the idea!
