From Friday, January 17th 11 PM CDT (January 18th 5 AM UTC) through Saturday, January 18th 11:30 AM CDT (January 18th 5:30 PM UTC), ni.com will undergo system upgrades that may result in temporary service interruption.
NI TestStand Idea Exchange
MOBA-User
Subsequence User Interface
Status: Already Implemented
MOBA-User,
Thanks for clarifying - i was assuming based on your description that you wanted an Edit UI for some kind of subsequence, not just a step (hence linking to the other post). You can accomplish that today via the workarounds listed in the link.
In our Company also hardware developer creates testsequences in teststand, so it would be nice, if there could be a small user interface to configure the values of the parameters for a subsequence.
The solution could be, if they drag and drop a sequence into their main testsequence, a user interface pops up to configure the parameters for this subsequence. So it would be possible to restrict the values with a drop down menu or Radio Buttons or to give some graphical help to choose the right values.
Or maybe i could create something similar to the IVI sequences, where i can click on a button and a small editor window is opened.
4 Comments
MOBA-User
OK i found this functionality under costum step types. There you could create an "Edit Substep" in the properties.
Everybody who is interested:
https://www.ni.com/en/support/documentation/supplemental/08/teststand-custom-step-type-development-b...
Or the tutorial:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x27RCAQ&l=en-US
(Unfortunately without the VIs in the .zip-File, but you get a quick overview)
WireWeaver
NI Employee (retired)
Status changed to: Duplicate
MOBA-User
I think the correct status would be: Already implemented. Because the posted idea is about a sequence adapter in the substeps, not about the edit substep or something similar.
WireWeaver
Status changed to: Already Implemented
MOBA-User,
