NI TestStand Idea Exchange
StephenGerads
Provide error logging
Status: Declined
I'm declining this due to lack of community support and the ease of a workaround. Also, a relevant feature was added in 2017 to log any crash info (not exactly the same, but harder to workaround):
https://zone.ni.com/reference/en-XX/help/370052W-01/tshelp/infotopics/2017whatsnew/#Crash
Under Station Options, Preferences, add selector for error logging to:
None
Client SequenceFile Directory
Specific directory
check box for: one file for each error
check boxes for parameters to log:
error time
error code
error message
sequence file
sequence
step
step action
MySocketIndex
3 Comments
ChrisHawk
I think this could be achieve by linking TestStand errors with the generation of OutputMessages.  If an OutputMessage was generated for every error then most of the information requested above is already in an OutputMessage.
However a feature to TestStand to log OutputMesages to a file would be needed. Maybe even allow the file path to be specified using macros like the report filename expression to allow different files per execution, thread, category,severity, etc if desired.  If feel this option would have the same development effort and provide a full event/error logging capability that could be tailored to suite many applications.
warren_scott
This is really easy to do with a custom result processor that just logs errors.  (starting with TestStand 2012).  Pretty much just a text style report with a custom filter expression.
WireWeaver
Status changed to: Declined
