NI TestStand Idea Exchange
MichaelMC
PDF report generator for teststand
Why not make it possible for Teststand to generate reports in PDF format?
It would make it a lot easier to send a testreport of a specific board to people not connected to the actual tester.
Today we use XML but this requires the stylesheet to be present on the readers pc.
Graphs are also not showing correct unless you do a manual setup of the settings in Internet Explore.
PDF would make my life a lot simpler
/Michael
16 Comments
Simplicity_Jon
We have had this requirement from several of our customers so a few years ago we created a custom process model with PDF reporting capability (now also ATML and csv). It is compatible with TestStand 4.1 and later.
http://www.simplicityai.co.uk/products_services/products/core_test_framework/#process_model
Jon Bowers
LabVIEW Architect, TestStand Architect
WireWeaver
Here is an example model plugin that automatically converts reports to PDF:
TestStand Model Plug-in: Printing Reports and Generating PDF Reports
WireWeaver
<duplicate>
WireWeaver
Status changed to: Under Consideration
WireWeaver
Status changed to: In Beta
You can sign up to see this feature at ni.com/beta
WireWeaver
Status changed to: Completed
