NI TestStand Idea Exchange
John_Speckhard
Organize sub-sequences in a sequence file more like file directory structure
Status: New
Often times a sequence file ends up containing dozens (or even hundreds) of sequences.  Currently they all show up in the sequence editor Sequence Window as a flat list.  It sure would be nice to view them organized in folders so that, for instance, all my sequences dealing with Rs485 communications or whatever could be group together in a "folder" called "RS485".  Also it would be great if there was a displayable property for each sequence showing the date/time last modified.  Then you could sort the list on that and see which sequences have changed. (really helpful if you have multiple guys who might be making changes.)
2 Comments
adambro
This is a very similar idea.
mavimi
Just to illustrate the idea as I see it:
I've also posted the illustration as a comment to the idea linked to by adambro
