NI TestStand Idea Exchange
jrasco
Match Container Values within Cluster during Prototype Re-load
Status: New
Defining a custom step type is an iterative process getting the Post Step VI, Edit VI, Step Type Fields, etc. all matched up and working together.  I often tweak controls and indicators throughout the process.  If I have defined the substeps in TestStand, that means reloading the VI prototype throughout this iteration.
If my controls/indicators are numerics, strings, or arrays of either, the existing parameter values are retained during the reload.  Containers are different, however.  If the cluster input of the VI is unchanged between the exisiting prototype and the reloaded version, the container parameter values are retained.  My complaint is that if one element in the cluster changes, the entire container gets thrown out during the reload.
In this particular case, all I did was change a cluster element from an array to an element.  Nothing else (cluster labels, etc.) changed.  Because of this, the entire container gets thrown out during the reload along with 30+ values that I had assigned.
Unfortunately, I find myself doing this multiple times during development so the time it takes to re-type everyhting adds up over the entire dev cycle.
My idea is to have container values retained (similar to non-container values) during a VI prototype reload.
Jacob
