I use the Stationglobals.ini to define my hardware settings on the test PC, like comport number and so on. It is running Teststand Base Deployment.
If I want to edit the settings it's only possible if I copy the stationglobals.ini to my development PC which has the full license, edits the settings, and then copies the file back to the test PC. Before I copy the file to my development PC I need to make a backup of the original file, so I don't get the settings on the development PC overwritten. Then afterwards I have to re-establish the backup.
This is a lot of copying back and forth, which is quite annoying.
Please make it possible to edit the Stationglobals.ini directly on the test PC with the Base Deployment Engine.
There are a number of workarounds listed and it looks like this was previously declined, but the status was not changed.
Trent
