When you use LabVIEW action steps, using enum as parameters, the enum update will generate your step to require a reload.
This behaviour is OK when current enum values are updated .... and the steps use the modified values !
But when adding a new enum value to the enum, the reload should not be automatic.
=> This behaviour doesn't happend with rings ...
Please make the enums works like rings for the LabVIEW actions steps reload !
Thanks a lot.
Manu.
