NI TestStand Idea Exchange
Elaine_R.
Improve Sequence Analyzer CommandLine to allow for automatic report generation
Status: Completed
Right now it appears the sequence analyzer has no really effective automation options?
I can use the command line to launch the Sequence Analyzer, but I really want to run this puppy headlessly against a codebase every 24 hours similar to how VI Analyzer works.  Ideally, yes, I'd love a full API, but for the short term, would it be possible to expand the command line?
what we have currently is:
AnalyzerApp.exe "C:\My Documents\MyProject.tsaproj"  to get the window open with the right project in it.
what would be seriously helpful would be to add: some sort of "-Run -Report "C:\Reports\MyProjectReport.xml""  additional tags?
In general I'd love for the tool to (1) launch, (2) run project, (3) save off file, and (4) close without further nagging on the part of a user.
 Extra kudos would be given if it could generate a standard-out message with some quick stats, if someone was feeling really gung-ho. Perhaps a # of rules, run and # of errors & warnings found?  I can just as easily rake the xml output, so these aren't required, but I am in dire need of a way to automatically _get_ that xml output.
If the tool already does these tasks than please feel free to say so?  I've combed the help in the versions I have installed, and so far have come up with nothing. I'm currently shopping around for a thin ui-robot to get the job done...
3 Comments
adambro
Some of this may have been implemented in 2014 SP1 which the release notes describes as including "Enhanced Sequence Analyzer application, with new command-line arguments to perform additional operations". You can find the help page for this at http://zone.ni.com/reference/en-XX/help/370052P-01/tsref/infotopics/sequence_analyzer/
Elaine_R.
I agree This feature definitely exists in 2014 SP1 and up.   May just be a forum update hiccup as this idea was pre SP1 and was probably supposed to be flagged as 'done' at that time 🙂
WireWeaver
Status changed to: Completed
