It will be good if a "Extract" sequence option present: When we select more than one steps in a sequence, show this option. Once you select extract option, new sequence should be created within the .seq file, and automatically insert a step "Sequence Call" which calls the new sequence.
As crossrulz pointed out, this feature is present in TestStand 2016 and later:
Creating a Subsequence from Selected Steps
-Trent
