NI TestStand Idea Exchange
Execution Object Property
Status: Declined
I'm declining this idea due to lack of community support.
This has to be an easy one, could you add a "EntryPoint" property to the execution object that would retrieve the execution entry point. This info is included in the Execution.DisplayName property but it is a little bit of a pain to trim/split the string to get the actual entry point name.
Thanks!
<< N >>
2 Comments
EMR
I could see this being handy, because unlike 'RunState.Root.Runstate.Sequence.Name' a new property could report a blank string when you're not running with the model (or if you want to see what the menu-selection choice was, and not the actual entry point sequence name was)... But the basic expression isn't a time consuming thing to implement either.
--Elaine
Cheers,
Elaine R.
www.bloomy.com
WireWeaver
Status changed to: Declined
