I'm trying to pull out all parameters from a sequence when it errors and save it as an additional result. This is to help the debugging process in a custom report plugin.
It falls over when enums are used as they can't be pulled out as GetValVariants then converted to strings.
I suggest that the if a variant for enum is called it keeps the number and string text inside of it "[5] Item number 6" for example. This can then be interpretted into a string by Str().
Example expression:
Locals.ConcParams = Locals.ConcParams + "Parameter: " + RunState.Caller.Parameters.GetNthSubProperty("",Locals.X,0).Name + " Value: " + Str(RunState.Caller.Parameters.GetNthSubProperty("",Locals.X,0).GetValVariant("",0))
Certified LabVIEW Architect
