NI TestStand Idea Exchange
paulmw
Enhance XML Packaging Utility
Status: Declined
I'm declining this due to limited support for the idea.
Thanks for the feedback!
Trent
It would be nice to add these features to the XML Packaging Utility:
1. Allow the changing of the stylesheet.  Currently the utility packs the XML with the specified stylsheet within the XML;  in some cases I'd like to define a different stylesheet for distributions.  This would also allow distributing reports if the specified stylesheet within the XML is not found.
2. Allow an option to have the "packed" files maintain the "Date modified" file properties.  I quite often use Windows to sort a folder of reports on the date modified attribute.  After packing, that info is lost.
3. Incorporate a zip file as an output
1 Comment
WireWeaver
Status changed to: Declined
Trent
