When developing code for the customization of the User (Operator) Interface, I would like the capability to provide my own custom dialog box for “Loop on Selected Steps” by overriding the standard dialog box that TestStand provides. TestStand provides this standard dialog box when the command kind “Loop On Selected Steps Using” is executed.
The problem in our production environment often is our production technicians are required to (manually) perform interactively with a series of sequence steps and repeat those steps 29 times (Our strict regulatory guidelines). Most of our technicians are technologically challenged in our production environment. In our environment, I have developed the TestStand User Interface to where the TestStand Execution and Sequence Views are hidden to production operators but visible to the developers (engineers) and administrators for trouble shooting capability.
If a custom dialog box cannot be done, at least provide the capability to where I can programmability change the properties of the “Loop On Selected Steps”. At least allow the dialog box to be programmability set to where I can set the number of loops, set the stop condition, stop expression, enable/disable the controls or hide the dialog box without the operator needing to manually entering those values into the dialog box.
I'm declining this idea due to lack of community support and the workaround provided above.
