It would be great to be able to generate a FileGlobal or a local variable by right clicking a detected field in a Sequence step and choosing the relevant option as shown in the image below:
If you type in "Locals.Variable_Name" in the Value part, you can right-click on that to create the local variable.
There are only two ways to tell somebody thanks: Kudos and Marked Solutions Unofficial Forum Rules and Guidelines "Not that we are sufficient in ourselves to claim anything as coming from us, but our sufficiency is from God" - 2 Corinthians 3:5
That solution is the same as just adding it manually in the variables pane. Maybe a little bit more convenient. If I have a cluster of clusters with different data types inside I'll have to sit all day to create the local variable manually instead of automatic generation, which should be straight forward.
I found this icon under the type column to be the closest thing to my suggestion. It creates a new type populated with everything inside:
But i find it as a partial solution. as it requires extra steps of actually creating a variable with the newly created type instead of just doing everything in one go as distinct types don't recure.
