I think it would be a great idea to allow the sequence adapter to expand containers like the CVI and LabVIEW adapters do when you are editing the module for the step.
See attachment.
jigg CTA, CLA testeract.com ~Will work for kudos and/or BBQ~
We just ran into this while trying to pass data into a subSequence. This would be a very nice feature to have. As it is, we will have to use local variables within the subsequence to pass our data as opposed to using parameters, which would make more sense. Tally another vote for this feature.
This would be a very helpful feature. I pass containers back and forth through sequence calls. I would be able to make the variables much cleaner if the containers were expandable. The sequence analyzer does not catch container mismatch, i.e if I edit the container later and forget to update the sub-sequence I am calling (since I pass the same contanier to multiple sub-sequences) then the sequence errors out during execution. I can catch these problems before finding them in production, if the container was expandable
Yes, please. I'm passing in a ton of parameters as options for my model plugin and I have to break them out individually as parameters, then set the typedef instance internally. (This is painful, especially if I have to add more options in the future)
If you want it then click the Kudo Star to register your vote. That is how the Idea Exchange works. Kudoes are votes. Just saying you want it implemented in a comment doesn't count.
