It's perhaps not quite as good as if they were built in, but you can use the .NET adapter to directly call into the mscorlib assembly (the main .NET framework assembly) which has an extensive file I/O API (See System.IO.FileStream).
Good suggestion. Thanks! I just figured that since TestStand already offers functions for strings, arrays, etc., it might be nice to also contain functions for file I/O.
https://zone.ni.com/reference/en-XX/help/370052W-01/tsref/infotopics/data_streams_readfromcsv/
