NI TestStand Idea Exchange
crlanglois
Add a Property Exporter step type
Status: New
I currently use property loader to load calibration data from a file during test.  I populate this file using export.  The problem is that now I want to write a calibration sequence as well and there is no property exporter step to do this programatically in TestStand.  I will end up writing my own code to create this to emulate the way that Import/Export does it but it would be nice if this was supported as a TestStand step.
2 Comments
skahlau
I also use the propertyloader to load some default values for the test.
During test the user can change these values via a GUI.
Now it would be nice to have these new values for the next start of TestStand.
So I like to save these values automatically when the user Exits the test.
RavensFan
Knight of NI
Well if you like the idea, then you should vote for it by clicking the Kudo start next to the message!
