TESTSTAND is capable of interfacing so many devices & instrument to a UUT.
Incase of ATE(Automatic test equipment), where lot of resources are made available to test the UUT, not all the resources or instruments will be used through out the test for a particular UNIT. Hence there should be facility to select the resources required for particular test, which will be then only initialized & used.
For example a simple power device requires only POWER SUPPLY, LOAD & DMM. Where as a data acquisition system requires POWER SUPPLY, DIO & AIO cards & so on.
Thus one should only select the resources required for test & hence no need to have init function separately for each sequence. This may sound a bit complicated but It really helps for LARGE ATEs, where optimization is KEY. Same thing can be implemented for TERMINATING resources once test is done.
I'm declining this idea due to lack of community support.
