06-18-2020 07:57 AM
Hi everyone,
just to make sure, I got that right.... for LabVIEW Modules which are intended to be used with several LabVIEW versions, a dedicated NIPackage has to be created for each LV version in order to have them installed into the respective <LabVIEW20xx>\instr.lib ?
Cheers
Oli
Solved! Go to Solution.
06-18-2020 09:30 AM
That is correct. NI Packages put files in a specific location on disk.
For more information:
NIPM Idea Exchange: Install the same package to multiple versions of LabVIEW
06-18-2020 09:41 AM
Thanks for the confirmation
