NI Package Manager (NIPM)
[Package Builder] Custom Execute "options" and quote support issue
Ok, so I've been banging my head against the wall for a while on this and am about to throw in the towel, as I'm not sure what I'm missing...
I have an NIPB build where i'm calling a custom created .bat file which takes some arguments (was hoping this .bat file would be a "reuse" file for some other builds...)
However, some of the arguments require quotes ("argument").
I've tried this a few different ways, but it seems that when you include the quote character (") in the build spec, NIPB for some reason saves this as (&quot) in the instructions file, and subsequently tries to call command line with that escaped character.
The article here: https://www.ni.com/documentation/en/ni-package-builder/latest/manual/customexecutes/
Suggests i'm doing things correctly.
But it's clearly not working correctly.  In order to "fix" the situation, I had to manually manipulate the custom action database as described here: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YPYfCAO&l=en-US
When doing this, it definitely highlights the issue...
An NI created custom execute looks like this:
One created using NIPB looks like this:
While the NIPB build looks like this:
A workaround is to build the arguments directly into the .bat file I'm calling... however I'd say this is pretty undesirable from a reuse perspective...
(202 Views)
young8711,
I believe you are hitting the following known issue from "NI Package Builder 20.6 Known Issues":
Bug Number: 1461850
Description:
Custom executes error during installation when arguments contain quote characters
Package Builder incorrectly creates the instructions file for a package when the arguments for a custom execute contains quote (") characters. The custom execute fails when Package Manager executes the command because quote characters are incorrectly expanded as "&quote;".
For example, configuring a custom execute to call a batch script as shown below returns the error "The executable returned error '1' after running the custom execute command."
Root: [System (32-bit)]
Relative Executable Path: cmd.exe
Arguments: /c ""%Program Files_64%\MyScriptFile.bat" "parameter 1" "parameter 2""
Workaround:
Downgrade to and build the package using Package Builder 20.5.
Details:
Reported Version: NI Package Builder 20.6
Resolved Version: N/A
Added: Jul 13, 2021
Scott Richardson
(173 Views)
Yup... that sounds right.
Good to know it was already reported... must have missed that when I was scanning through those.
(169 Views)
