01-20-2022 01:55 PM - edited 01-20-2022 02:03 PM
Trying to install DAQmx 19.1 on a Windows 7 32-bit computer. The first thing the installer tries to do is install NI Package Manager 20.6. Immediately, the Package Manager installer crashes, with Windows saying "NI Package Manager Installer has stopped working." As a result, I can't install DAQmx.
I read that Package Manager stopped supporting Windows 7 in 2021, though I am not sure if that is causing this issue. Moreover, I can't find a way to download an older version of Package Manager.
Any help? Thank you!
01-25-2022 03:50 PM
Does anyone have any insight into this issue?
01-25-2022 07:11 PM - edited 01-25-2022 07:13 PM
Try this:
The idea is that this will update the NIPM engine on your system to the latest, which is what the DAQmx 19.1 installer will then use.
01-27-2022 03:18 PM
Thanks for your response. Our client PC is in China and will be off until after Chinese New Year in February. Once it's back online, I will try your suggestion and let you know what happens.
