Hi
The available features of NI package Manager allows us to view the customized packages(that published in the registered feeds) and NI Realted packages with few filters based on their maintainers and category within the packages Tab. We are in need to view a subset of packages which includes some custom packages and NI driver packages alone under packages Tab. We thought of some methods but all that had some difficulties along with it.
1.We could able to either add the NI driver packages to our feed but there is no separate filter to view the packages published in a particular feed alone and also there are numerous Ni driver packages which was not that easy to publish in our feed which will bring much complexity in the existing system.
2.we could utilize the available filters to make our own subset of packages to be under packages Tab. Is there any way to automate the filters which will provide initial view of NIPM with only desired packages to be visible to the user? I went through the built in browse commands and was not sure about commands regarding automating the filtering options available in NIPM.
It would be useful if you provide some suggestions to achieve our requirement.
