This document is part of the NI Package Management Portal.
Introduction to NI Package Manager (NIPM) Feeds
To distribute NIPM packages, you can deliver individual package files (.nipkg) to recipients, or you can create a feed to which recipients register.
What is a Feed?
A feed is a collection of files that includes a manifest containing information on the feed’s included packages. A feed should include any packages you want to distribute and typically any packages that are required dependencies. NI recommends using a feed when you need to distribute multiple packages that have dependencies on one another. With feeds, you can create a single location where you host and maintain all packages intended for end-user access.
Hosting and Managing a Feed
You can host a feed on any of the following:
Managing a feed includes the following tasks:
If you want to host a feed on a local/network folder, then you can use the NI Package Manager API to create and manage the feed(s) If you want to host a feed on a web server, provide granular user permissions/roles for managing feeds, and/or push mass-deployments, then you can buy and use SystemLink to create, host, and manage the feed(s).
Registering a Feed
For a target computer to see and install package in a feed, the target computer must register the feed. You can register feeds on a target computer using NI Package Manager or SystemLink.
For more information, refer to the following links:
