NI Package Management Idea Exchange
ChristianNeumann
Add an "remove all" feature to the NIPKG command line interface
Status: Already Implemented
The nipkg.exe help lists the following which supports the ability to remove all packages, see bold text:
nipkg remove [OPTIONS] [PACKAGES]
Uninstalls previously installed package(s).
Use "nipkg remove" to remove all packages except locked and essential
packages and their dependencies.
Use "nipkg remove --force-essential --force-locked" to remove all packages
including locked, essential, and NI Package Manager packages.
The old installer had an option to remove all NI Software via the command line:
Automating Uninstallation of NI Software - National Instruments
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019LfWSAU&l=en-US
While the nipk  command line interface has the "remove" option there is no "remove all" feature. It is only possible to remove single packages.
Dr. Christian Neumann
NI Germany
7 Comments
APena
Status changed to: Development Started
APena
Hi Christian,
A quick question just to get a little more detail:
NIPM itself is installed as a package. Would you expect a 'remove all' command to also uninstall NIPM itself?
Thanks.
 - Aaron
ChristianNeumann
NI Employee (retired)
Hi Aaron,
thank you for your reply.
Yes, I would expect that the 'remove all' command also uninstalls the NIPM.
NI Germany
CL_eisenwr
I think it would also be nice to have an option to remove all except for NIPM
__________________________________
Bill Eisenhower
Certified LabVIEW & TestStand Developer
ChrisStrykesAgain
I think this is an important feature, and could have used it today. I'd usually want it to not uninstall NIPM, but I think the more appropriate action would be for it to literally uninstall everything (including NIPM) by default; I wouldn't be upset if that was the only option.
That said, in the interim, I did the following: https://forums.ni.com/t5/NI-Package-Manager-NIPM/Remove-all-NI-packages/td-p/3997583
APena
Status changed to: In Development
We are actively working on this functionality for our next release. Take that with all of the usual disclaimers about the possibility of features getting pulled before a release, etc. etc. 🙂
Thanks.
 - Aaron
Scott_Richardson
Status changed to: Already Implemented
Scott Richardson
