NI Linux Real-Time Documents
NI Linux Real-Time and opkg: Introduction to ipks
Overview
With the release of NI Linux Real-Time for PXI and further improvements to the NI Linux Real-Time platform, NI now utilizes ipks for software installation using the opkg package manager that ships with NI Linux Real-Time.
Description
The attached tutorial covers:
  • Creation of a simple "Hello, World!" executable
  • Packaging the executable in an ipk for distribution with the opkg package manager
  • The document also includes a more general discussion for how to build an ipkg and feeds
Note: NI Support does not officially support the usage of custom ipks. If issues are encountered, NI recommends posting to NI Linux Real-Time community forums for assistance from other NI Linux Real-Time users.
Hardware and Software Requirements
  • NI Linux Real-Time System with one of the following
    • Access to the online NI Repositories or an offline version of the repo copied from the
    • Source for a Linux Package (this tutorial includes source code for a "Hello, World!" example
Brian D.
Comments
RVallieu
Active Participant
Active Participant
on
Ok I created the HelloWorld.c file on my system and was able to utilize the gcc tools installed to compile to code.  Yes!
Next I tested the executable by running the compiled exe using
# ./hello
Rewarded by
Hello world!
printed on the screen.
With that success I then tried to follow the directions to build the opkg ipk.
I created the hellopgk folder
hellopgk
    CONTROL {directory}
         control {text file}
    usr {directory}
        bin {directory}
            hello {exe created by gcc compile and tested above}
        lib {folder}
    deiban-binary {text file? with 2.0}
Then I navigated to the opkg-utils folder on my system and ran
./opkg-build /SystemPath/hellowworld/hellopkg /SystemPath/helloworld
This DID build the hellopkg_1.0.0_x64.ipk
However, when I ran opkg install hellopkg_1.0.0_x64.ipk  I got errors unrelated to this package popping up, from a failed prior opkg install...
Any clue on why a prior install error would stick around?
When I did an opkg info hellopkg after the failed install, it returned nothing.
Ryan Vallieu CLA, CLED
Senior Systems Analyst II
NASA Ames Research Center
Contributors
