The ni-rt.ini vs. lvrt.ini question came about from a desire to do away with the ini altogether (and yet we ended up with two... yeah...) Basically, LabVIEW RT Runtime-specific changes should go in the lvrt.ini file (including the logging settings you're referencing).
System-wide changes should go in the ni-rt.ini file. Note, however, the vast majority of tokens that are defined for this use-case are accessible through MAX or there's little reason to change them, so except for certain circumstances, you shouldn't be editing this file. One of those "certain circumstances" would be the desire to avoid using MAX, I suppose, but you do so at your own risk.
