‎02-08-2017 12:04 PM - edited ‎02-08-2017 12:16 PM
iam using MyRIO 1900 that have WIFI , i have problem with the WIFI
when i connect myrio through usb i can not change any thing on it, in wireless adapter wlan0 the wireless mode always disable i dont have any option ti change it why ?
how to enable the wifi ?
so i can change the mode of it
Solved! Go to Solution.
‎02-08-2017 01:37 PM
First and foremost, welcome!
Next in order of importance is that this sort of issue is likely best served on the official NI support forums, not the community forums (http://forums.ni.com/t5/Discussion-Forums/ct-p/discussion-forums, the RT subsection under LabVIEW).
Next, what version of LVRT and RIO are you using with your myRIO 1900?
Finally, what software interaction/installation/shell interaction (e.g. through MAX, ssh, or the serial console) have you done with the target?
‎02-09-2017 01:22 AM
Thank you for your response
I am using vesion 15.0, with NI-MAX
I hope that will help
‎02-10-2017 04:27 PM
Well, I don't know what to tell you other than "works for me". Try formatting your target and trying again.
From a 2015 stack:
‎02-10-2017 04:39 PM - edited ‎02-10-2017 04:46 PM
i already format it but nothing change
as you can see in the pic i don't even have any chance to change the option
‎02-10-2017 04:43 PM - edited ‎02-10-2017 04:48 PM
even if i try to change the country it gave me error
‎02-10-2017 05:30 PM
Enable either the ssh shell or serial console, log into the target, post the results of running the command ip link show
‎02-10-2017 05:33 PM
where i have to enter that command ?
‎02-11-2017 08:17 PM - edited ‎02-11-2017 08:18 PM
Please see: How Do I Access the Shell on a NI Linux Real-Time OS Device?, and run the command from the myRIO's shell.
‎02-12-2017 11:07 AM
here is the result , so what i have to do after that ?
