07-10-2020 12:57 PM
This looks like it will work
07-10-2020 02:31 PM
Worked, thanks for the reminder.
07-14-2020 09:59 AM - edited 07-14-2020 10:06 AM
Experimenting - I changed the rtexe to run at start-up. Tehn rebooted, and stopped the program.
Then ran the script file to launch the rtexe again - this time the VI appeared on the gui, but then quit.
"Startup Application:/home/lvuser/natinst/bin/startup.rtexe
Welcome to LabVIEW 19.0.1f1
LabVIEW caught fatal signal
19.0.1f1 - Received SIGSEGV
Reason: Address not mapped to object
Attempt to reference address: 0x0x7f07c8005104
./lvrt-manuallaunch: line 6: 11673 Segmentation Fault /usr/local/natinst/etc/init.d/lvrt-wrapper $STARTUP_PARAM $PID_LVRT_WRAPPER SUI_ENABLED"
When I don't set it to Run as Startup and run the bash file to launch lvrt-wrapper - it simply stops at
"Welcome to LabVIEW Real-Time 19.0.1f1"
And doesn't open the VI front panel....odd.
07-22-2020 04:39 PM
Oops had a Front Panel open property in a VI - removed that.
No more Segment faults.
The RTEXE has to be set to Run as Startup for the lvrt-wrapper call to launch the VI - which is kind of annoying. I'll have to see if I can avoid having to use that setting. It's not looking that promising.
I can't find any information about /usr/local/natinst/labview/lvrt binary
Hm...
07-24-2020 04:08 PM
Don't bother. It won't work without it.
07-24-2020 04:11 PM
Well shoot. That's annoying.
I guess I will be replacing xinetd with just a LabVIEW exe to monitor the ports of interest and launch applicable code.
07-31-2020 11:44 AM
Had another idea -
So I have to have the system set to Run as Start-up - fine.
I can create start-up script to run to set a flag in an INI file to False (do not run LV Code) that my code will check on start.
I can set the start-up script to run before the LVRT Daemon start-up process I believe.
Then I add code to the xinetd start-up script I created that first sets the flag to TRUE to allow the startup.exe code to run.
Thus is we ever have a power-up event the system won't just up an run the LabVIEW code and will wait for xinetd to open the connection.
I am still struggling to prove that xinetd will pass the information to/from the LabVIEW EXE - I guess that is the next step again after I prove I can get a start-up script to work to shut down my code via flag and then the shell script that xinetd will call can start it.
07-31-2020 02:06 PM
How set in stone is an inetd-style load process again? Because it usually tends to simplify system operation, and this is moving very far away from that.
07-31-2020 02:08 PM
It's how all the other systems and legacy systems are set up. This isn't that much more complicated compared to rewriting all the other system code.
09-11-2020 06:22 PM
Well I actually got xinetd to run a service and change the run Flag to TRUE when I connected from a TCP client on my laptop to the PXIe on the port specified in the service, now I just need to incorporate the start of the LVRT EXE into that shell script.
Then I need to see if I can pass information through the xinetd connection... 😕
