02-10-2016 06:14 AM
Hi guys,
Has this been solved yet?
I ran into the same problem.
I've also an eGalax touchpanel wich I want to use with my CVS-1458RT
same behaviour: mouse movement works like a charm, but can only click once.. and then the clicking event does not work anymore.
A solution would be that I use the windows version for the CVS but that's my last option..
Bruno
02-10-2016 10:25 AM
Can you try an experiment?
Copy the attached '05-egalax-virtual.conf' file on the target in '/usr/share/X11/xorg.conf.d'. You will have to do this as 'admin' (i.e. 'lvuser' doesn't have permissions to write at that location). Reboot the target and let us know if there are any changes in the way the touchscreen reacts.
Also post the following log file (after you reboot): /var/log/Xorg.0.log
The output from running 'lsusb -vvv' on the target would also be helpful. You will have to install 'usbutils' to get the command. You can do it by running 'opkg update' followed by 'opkg install usbutils'
02-11-2016 02:07 AM
Still the same behaviour with when I put this file into the '/usr/share/X11/xorg.conf.d folder
IN annex the Xorg.0.log
I'll try the lsusb thing today..Regards,
Bruno
02-11-2016 02:26 AM
THe output from lsusb -vvv is:
Bus 001 Device 002: ID 0eef:0001 D-WAV Scientific Co., Ltd eGalax TouchScreen
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 1.10
bDeviceClass 0 (Defined at Interface level)
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x0eef D-WAV Scientific Co., Ltd
idProduct 0x0001 eGalax TouchScreen
bcdDevice 1.00
iManufacturer 1 eGalax Inc.
iProduct 2 USB TouchController
iSerial 0
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 59
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 1 eGalax Inc.
bmAttributes 0xa0
(Bus Powered)
Remote Wakeup
MaxPower 100mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 3 Human Interface Device
bInterfaceSubClass 1 Boot Interface Subclass
bInterfaceProtocol 2 Mouse
iInterface 0
HID Device Descriptor:
bLength 9
bDescriptorType 33
bcdHID 2.10
bCountryCode 0 Not supported
bNumDescriptors 1
bDescriptorType 34 Report
wDescriptorLength 341
Report Descriptors:
** UNAVAILABLE **
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0040 1x 64 bytes
bInterval 3
** UNRECOGNIZED: 19 ff 42 49 53 54 00 01 02 03 ff 00 00 00 00 00 01 04 b8 0b 02 05 b8 0b 00
Device Status: 0x0000
(Bus Powered)
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bDeviceSubClass 0 Unused
bDeviceProtocol 1 Single TT
bMaxPacketSize0 64
idVendor 0x1d6b Linux Foundation
idProduct 0x0002 2.0 root hub
bcdDevice 3.10
iManufacturer 3 Linux 3.10.31-ltsi-rt29-2.10.0f0 xhci_hcd
iProduct 2 xHCI Host Controller
iSerial 1 0000:00:14.0
bLength 9
bDescriptorType 2
wTotalLength 25
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 9 Hub
bInterfaceSubClass 0 Unused
bInterfaceProtocol 0 Full speed (or root) hub
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0004 1x 4 bytes
bInterval 12
Hub Descriptor:
bLength 9
bDescriptorType 41
nNbrPorts 6
wHubCharacteristic 0x000a
No power switching (usb 1.0)
Per-port overcurrent protection
TT think time 8 FS bits
bPwrOn2PwrGood 10 * 2 milli seconds
bHubContrCurrent 0 milli Ampere
DeviceRemovable 0x7c
PortPwrCtrlMask 0xff
Hub Port Status:
Port 1: 0000.0103 power enable connect
Port 2: 0000.0100 power
Port 3: 0000.0100 power
Port 4: 0000.0100 power
Port 5: 0000.0100 power
Port 6: 0000.0100 power
Device Status: 0x0001
Self Powered
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 3.00
bDeviceClass 9 Hub
bDeviceProtocol 3
bMaxPacketSize0 9
idProduct 0x0003 3.0 root hub
bcdDevice 3.10
bLength 9
bDescriptorType 2
wTotalLength 31
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
bMaxBurst 0
Hub Descriptor:
bLength 12
bDescriptorType 42
nNbrPorts 1
bHubDecLat 0.0 micro seconds
wHubDelay 0 nano seconds
DeviceRemovable 0x00
Hub Port Status:
Port 1: 0000.02a0 5Gbps power Rx.Detect
Binary Object Store Descriptor:
bLength 5
bDescriptorType 15
wTotalLength 15
bNumDeviceCaps 1
SuperSpeed USB Device Capability:
bLength 10
bDescriptorType 16
bDevCapabilityType 3
bmAttributes 0x02
Latency Tolerance Messages (LTM) Supported
wSpeedsSupported 0x0008
Device can operate at SuperSpeed (5Gbps)
bFunctionalitySupport 3
Lowest fully-functional device speed is SuperSpeed (5Gbps)
bU1DevExitLat 10 micro seconds
bU2DevExitLat 512 micro seconds
Self Powered
02-11-2016 03:57 AM
Hi Gratian,
the same wrong behavor with the virtual conf file too..
attached the Xlog a lsusb log files.
regards
02-11-2016 08:40 AM
As I told before, the EV_TOUCH value of code 330 is always high on my touch screen. I.ve tried to force the value to be 0 after the touch tapping with the C code:
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <linux/input.h>
#include <fcntl.h>
#define MOUSEFILE "/dev/input/event7"
int main()
int fd;
struct input_event ie;
if((fd = open(MOUSEFILE, O_RDWR)) == -1) {
perror("opening device");
exit(EXIT_FAILURE);
ie.type = EV_KEY;
ie.code = 330;
ie.value = 0;
write(fd,&ie, sizeof(ie));
printf("write type %d\tcode %d\tvalue %d\n",
ie.type, ie.code, ie.value);
return 0;
Ufortunatelly, even if the value is resetted to 0, the monitor touch doesn't work. May be it depends by other driver.
I will try to add the HIDRAW module on the kernel as suggested by eGalax
Bye
02-11-2016 10:44 AM
Biebel,m-power,
In order to configure and build a kernel with the HIDRAW support that eGalax is calling for:
Basically, you should have someone who's a bit more experienced working with Linux run through these steps, as I don't really have a x64 target to test this out on and there may be missing steps or steps that need to be adjusted.
This may seem like quite a bit of pain/annoyance, but keep in mind that touch panels with the eGalax touch controller were never tested nor suggested that they would be supported. This is the reason that NI resold touch panel displays with many mounting options and thoroghly tested those. There are simply too many options out there and Linux touch screen support is fairly low on many of the touchscreen manufacture's list of concerns.
02-12-2016 08:14 AM
HI,
I was finally able to build the kernel with HIDRAW, uinput and evdev options enabled.
Now it created 3 folders:
-boot (with the bzImage in)
-headers
-lib
I know I need to be carefull now, and because I never replaced a kernel, I would appreciate it when you tell the next steps?
Bruno
02-12-2016 08:44 AM
Again, I don't have a x64 target in front of me, but the good news is that you can always force the target to boot into Safe Mode and reformat through MAX.
Pulling from recollection, the .../boot/bzImage will go to the /boot/runmode/, replacing the existing bzImage (you can optionally copy the existing to something like "bzImage.old")
The .../lib/ directory contains the modules/firmware for this recompilation of the kernel. Copy the content of this folder to your /lib directory (if you are in Run Mode/LVRT-mode currently)
The .../headers/ directory contains a headers.squashfs. Copy (and rename) this file to replace the existing kernel's header squashfs at /usr/local/natinst/tools/module-versioning-image.squashfs (again, you can rename the old to keep it around)
Once all of these have been done, reboot your target. When it comes back up, either check in MAX or run uname -a from a console to make sure that you're using the new kernel (check the date of the build, and note that it will match the time as set on your target, as that's where the kernel was built)
02-12-2016 09:56 AM
ofcourse it failed booting.
Now I'm back on the old kernel (went through the faile safe mode etc)
I should start with a default configuration of national instruments I think, but I didn't find the nati_x86_64_defconfig file, only the x86_64_defconfig file...
