NI Linux Real-Time Discussions
Unable to compile uinput module on cRIO 9030
Hi guys,
Has this been solved yet?
I ran into the same problem.
I've also an eGalax touchpanel wich I want to use with  my CVS-1458RT
same behaviour: mouse movement works like a charm, but can only click once.. and then the clicking event does not work anymore.
A solution would be that I use the windows version for the CVS but that's my last option..
Bruno
Message 31 of 73
(2,189 Views)
Can you try an experiment?
Copy the attached '05-egalax-virtual.conf' file on the target in '/usr/share/X11/xorg.conf.d'. You will have to do this as 'admin' (i.e. 'lvuser' doesn't have permissions to write at that location). Reboot the target and let us know if there are any changes in the way the touchscreen reacts.
Also post the following log file (after you reboot): /var/log/Xorg.0.log
The output from running 'lsusb -vvv' on the target would also be helpful. You will have to install 'usbutils' to get the command. You can do it by running 'opkg update' followed by 'opkg install usbutils'
Message 32 of 73
(2,189 Views)
Still the same behaviour with when I put this file into the '/usr/share/X11/xorg.conf.d folder
IN annex the Xorg.0.log
I'll try the lsusb thing today..Regards,
Bruno
Message 33 of 73
(2,189 Views)
THe output from lsusb -vvv is:
Bus 001 Device 002: ID 0eef:0001 D-WAV Scientific Co., Ltd eGalax TouchScreen
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               1.10
  bDeviceClass            0 (Defined at Interface level)
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  idVendor           0x0eef D-WAV Scientific Co., Ltd
  idProduct          0x0001 eGalax TouchScreen
  bcdDevice            1.00
  iManufacturer           1 eGalax Inc.
  iProduct                2 USB TouchController
  iSerial                 0
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength           59
    bNumInterfaces          1
    bConfigurationValue     1
    iConfiguration          1 eGalax Inc.
    bmAttributes         0xa0
      (Bus Powered)
      Remote Wakeup
    MaxPower              100mA
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         3 Human Interface Device
      bInterfaceSubClass      1 Boot Interface Subclass
      bInterfaceProtocol      2 Mouse
      iInterface              0
        HID Device Descriptor:
          bLength                 9
          bDescriptorType        33
          bcdHID               2.10
          bCountryCode            0 Not supported
          bNumDescriptors         1
          bDescriptorType        34 Report
          wDescriptorLength     341
         Report Descriptors:
           ** UNAVAILABLE **
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes            3
          Transfer Type            Interrupt
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0040  1x 64 bytes
        bInterval               3
        ** UNRECOGNIZED:  19 ff 42 49 53 54 00 01 02 03 ff 00 00 00 00 00 01 04 b8 0b 02 05 b8 0b 00
Device Status:     0x0000
  (Bus Powered)
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bDeviceSubClass         0 Unused
  bDeviceProtocol         1 Single TT
  bMaxPacketSize0        64
  idVendor           0x1d6b Linux Foundation
  idProduct          0x0002 2.0 root hub
  bcdDevice            3.10
  iManufacturer           3 Linux 3.10.31-ltsi-rt29-2.10.0f0 xhci_hcd
  iProduct                2 xHCI Host Controller
  iSerial                 1 0000:00:14.0
    bLength                 9
    bDescriptorType         2
    wTotalLength           25
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         9 Hub
      bInterfaceSubClass      0 Unused
      bInterfaceProtocol      0 Full speed (or root) hub
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0004  1x 4 bytes
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             6
  wHubCharacteristic 0x000a
    No power switching (usb 1.0)
    Per-port overcurrent protection
    TT think time 8 FS bits
  bPwrOn2PwrGood       10 * 2 milli seconds
  bHubContrCurrent      0 milli Ampere
  DeviceRemovable    0x7c
  PortPwrCtrlMask    0xff
Hub Port Status:
   Port 1: 0000.0103 power enable connect
   Port 2: 0000.0100 power
   Port 3: 0000.0100 power
   Port 4: 0000.0100 power
   Port 5: 0000.0100 power
   Port 6: 0000.0100 power
Device Status:     0x0001
  Self Powered
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               3.00
  bDeviceClass            9 Hub
  bDeviceProtocol         3
  bMaxPacketSize0         9
  idProduct          0x0003 3.0 root hub
  bcdDevice            3.10
    bLength                 9
    bDescriptorType         2
    wTotalLength           31
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
        bMaxBurst               0
Hub Descriptor:
  bLength              12
  bDescriptorType      42
  nNbrPorts             1
  bHubDecLat          0.0 micro seconds
  wHubDelay             0 nano seconds
  DeviceRemovable    0x00
Hub Port Status:
   Port 1: 0000.02a0 5Gbps power Rx.Detect
Binary Object Store Descriptor:
  bLength                 5
  bDescriptorType        15
  wTotalLength           15
  bNumDeviceCaps          1
  SuperSpeed USB Device Capability:
    bLength                10
    bDescriptorType        16
    bDevCapabilityType      3
    bmAttributes         0x02
      Latency Tolerance Messages (LTM) Supported
    wSpeedsSupported   0x0008
      Device can operate at SuperSpeed (5Gbps)
    bFunctionalitySupport   3
      Lowest fully-functional device speed is SuperSpeed (5Gbps)
    bU1DevExitLat          10 micro seconds
    bU2DevExitLat         512 micro seconds
  Self Powered
Message 34 of 73
(2,189 Views)
Hi Gratian,
the same wrong behavor with the virtual conf file too..
attached the Xlog a lsusb log files.
regards
Message 35 of 73
(2,189 Views)
As I told before, the EV_TOUCH value of code 330 is always high on my touch screen. I.ve tried to force the value to be 0 after the touch tapping with the C code:
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <linux/input.h>
#include <fcntl.h>
#define MOUSEFILE "/dev/input/event7"
int main()
    int fd;
    struct input_event ie;
    if((fd = open(MOUSEFILE, O_RDWR)) == -1) {
        perror("opening device");
        exit(EXIT_FAILURE);
ie.type = EV_KEY;
ie.code = 330;
ie.value = 0;
write(fd,&ie, sizeof(ie));
                    printf("write type %d\tcode %d\tvalue %d\n",
               ie.type, ie.code, ie.value);
    return 0;
Ufortunatelly, even if the value is resetted to 0, the monitor touch doesn't work. May be it depends by other driver.
I will try to add the HIDRAW module on the kernel as suggested by eGalax
Bye
Message 36 of 73
(2,189 Views)
Biebel,m-power,
In order to configure and build a kernel with the HIDRAW support that eGalax is calling for:
  1. Enable ssh on your target and login
  2. opkg update
  3. opkg install git
  4. opkg install ncurses-dev
  5. opkg install bc
  6. opkg install coreutils
  7. opkg install --force-downgrade packagegroup-core-buildessential libz-dev
  8. cd
  9. git clone git://git.kernel.org/pub/scm/fs/squashfs/squashfs-tools.git
  10. cd squashfs-tools/squashfs-tools
  11. make && make install
  12. cd
  13. git clone git://github.com/ni/linux
  14. git checkout nilrt/$RELEASE/$KERNEL_VER
    • For 2015, this will be nilrt/15.0/3.14
  15. make nati_$TARGET_defconfig
    • E.g. for your vision targets, you'll use nati_x86_64_defconfig
  16. make menuconfig
    • To enable HIDRAW, Device Drivers→HID suport→HID bus support→/dev/hidraw raw HID device support ('Y' to enable)
  17. make ni-pkg
    • This will create a kernel, modules, and headers squashfs (needed for NI driver reinstallation)
Basically, you should have someone who's a bit more experienced working with Linux run through these steps, as I don't really have a x64 target to test this out on and there may be missing steps or steps that need to be adjusted.
This may seem like quite a bit of pain/annoyance, but keep in mind that touch panels with the eGalax touch controller were never tested nor suggested that they would be supported. This is the reason that NI resold touch panel displays with many mounting options and thoroghly tested those. There are simply too many options out there and Linux touch screen support is fairly low on many of the touchscreen manufacture's list of concerns.
Message 37 of 73
(2,189 Views)
HI,
I was finally able to build the kernel with HIDRAW, uinput and evdev options enabled.
Now it created 3 folders:
-boot (with the bzImage in)
-headers
-lib
I know I need to be carefull now, and because I never replaced a kernel, I would appreciate it when you tell the next steps?
Bruno
Message 38 of 73
(2,189 Views)
Again, I don't have a x64 target in front of me, but the good news is that you can always force the target to boot into Safe Mode and reformat through MAX.
Pulling from recollection, the .../boot/bzImage will go to the /boot/runmode/, replacing the existing bzImage (you can optionally copy the existing to something like "bzImage.old")
The .../lib/ directory contains the modules/firmware for this recompilation of the kernel. Copy the content of this folder to your /lib directory (if you are in Run Mode/LVRT-mode currently)
The .../headers/ directory contains a headers.squashfs. Copy (and rename) this file to replace the existing kernel's header squashfs at /usr/local/natinst/tools/module-versioning-image.squashfs (again, you can rename the old to keep it around)
Once all of these have been done, reboot your target. When it comes back up, either check in MAX or run uname -a from a console to make sure that you're using the new kernel (check the date of the build, and note that it will match the time as set on your target, as that's where the kernel was built)
Message 39 of 73
(2,189 Views)
ofcourse it failed booting.
Now I'm back on the old kernel (went through the faile safe mode etc)
I should start with a default configuration of national instruments I think, but I didn't find the nati_x86_64_defconfig file, only the x86_64_defconfig file...
Message 40 of 73
(2,189 Views)
