05-20-2015 04:07 AM
It worked.
I installed and replaced the old non working rtl8192cu modules.
I then had to blacklist rtlwifi that was blocking rtl8192cu from working properly
(At this point, wlan0 was finally discovered by the OS)
I then I had to build up a wpa_supplicant.conf with
wpa_supplicant -B -iwlan0 -c/etc/wpa_supplicant.conf -Dwext && dhclient wlan0
and then ifconfig wlan0 up and got internet on the myRIO
Thank you very much for your help
05-20-2015 10:05 AM
Hey, glad to see you ignored my nay-saying and got it working anyway![]()
07-03-2015 01:02 PM
Hey am trying to do what you did, i have the same problem of installing the edimax drivers on the NI myrio 1950..please am requesting you to take me through the entire procedure, i downloaded the drivers for the edimax..but i have issues compiling them
07-03-2015 07:15 PM
What issues are you seeing? What steps did you do up to this point?
07-04-2015 05:20 AM
I tried to follow the tutorial you made but got stuck on stage 3of running the makefile.
On entering: source/ use/local/natinst/tools/versioning_utils.sh
I get this response: no such file or directory
And still, what does source refer to in that line
07-05-2015 03:01 PM
First, let's check that you're using a version of the software that supports the functionality that you need. Post the result of running "uname -a"
Secondly, it should be "source[space]/usr/local/natinst/tools/versioning_utils.sh". " Source " basically tells the shell to use a shell script to modify the environment of the currently running shell (set environment variables, define new functions, etc)
07-06-2015 01:07 AM
The result of uname -a
admin@NI-myRIO-1950-03047863:/rtl8192CU_linux_v2.0.939.20100726# uname -a
Linux NI-myRIO-1950-03047863 3.2.35-rt52-1.0.0f1 #1 SMP PREEMPT RT Wed Jun 12 09:57:26 CDT 2013 armv7l GNU/Linux
Result of source /usr/local/natinst/tools/versioning_utils.sh
admin@NI-myRIO-1950-03047863:/rtl8192CU_linux_v2.0.939.20100726# source /usr/local/natinst/tools/versioning_utils.sh
-bash: /usr/local/natinst/tools/versioning_utils.sh: No such file or directory
07-06-2015 08:41 AM
You do not have the needed version of the OS that has support for the needed functionality. That script does not exist in the 13.0 version of the OS.
You can update to a 14.0+ RIO on your development machine, format and reinstall with the newer RIO (choose a Custom Installation), and that will give you an OS with the needed functionality.
07-30-2015 02:40 AM
Hi, I have a question related with this thread.
I am trying to use USB wifi dongle with Linux RT device (myRIO-1950).
It seems that you could communicate with myRIO through the dongle,
I want to ask you some question.
- Is the device able to be recognized on MAX as network device like myRIO-1900?
- Do you have some following files?
+- dmesg log
+- boot log
+- lsmod log
we want to check by reading these files whether our device is working correctly.
Best,
07-30-2015 04:36 AM
~# ping google.com
PING google.com (216.58.209.238): 56 data bytes
64 bytes from 216.58.209.238: seq=0 ttl=56 time=40.002 ms
64 bytes from 216.58.209.238: seq=1 ttl=56 time=33.925 ms
64 bytes from 216.58.209.238: seq=2 ttl=56 time=39.490 ms
~# ping 192.168.0.1
PING 192.168.0.1 (192.168.0.1): 56 data bytes
64 bytes from 192.168.0.1: seq=0 ttl=64 time=68.425 ms
64 bytes from 192.168.0.1: seq=1 ttl=64 time=9.296 ms
64 bytes from 192.168.0.1: seq=2 ttl=64 time=8.793 ms
