NI Linux Real-Time Discussions
Running a c++ program cross compiled via putty in myRio-1900
Can I cross compile a c++ program using NI recommended compiler GNU C and C++ Compiler for ARMv7 Linux (Windows host). Then copy the program to myRio-1900 /home/lvuser/folder. And run the executable via putty?
Can I run the program without labview? Not using Labview and FPGA Interface C API
(2,709 Views)
Accepted by shebin
Hi shebin,
Yes, this is absolutely possible. You can also setup the binary to run on boot using a boot script as described in Tutorial: Installing Startup Scripts on NI Linux Real-Time. Let us know if you run into issues.
(2,673 Views)
(2,655 Views)
