NI Linux Real-Time Discussions
Openvpn at startup
Hey I added a client.conf file in my /etc/openvpn directory
This client.conf allows me to connect to my openvpn server
When I run openvpn client.conf it's working perfectly
Now I want this connection to start automatically at startup. How can I do that?
(4,699 Views)
I found
Just run
update-rc.d openvpn default
(4,394 Views)
I suppose that will work but it's not the recommended method. Look at /etc/init.d/vpn and in turn /usr/sbin/vpnctl. IIRC:
  • store everything in /etc/natinst/share/openvpn
  • make sure the directory and all files are owned by openvpn:openvpn and are not world-readable
  • set up the server for TAP mode
The upshot is that, unlike using /etc/openvpn, all of this should work in safemode as well as runmode: /etc/natinst/share is on a separate partition that is read by both runmode and safemode, and safemode has /etc/init.d/vpn and /usr/sbin/vpnctl baked into it. In fact, it's even persisted across reformats, if you specify preserving the network settings.
(4,394 Views)
I have a problem with openvpn startup:
https://forums.ni.com/t5/LabVIEW/OpenVPN-Startup-is-killed-by-CRIO/m-p/3649258/highlight/false#M1024...
Could you be more specific with your answer please. Maybe your solution can my problem!
Thanks a lot
(4,009 Views)
