If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
NI Linux Real-Time Discussions
Move file to u drive (usb flash drive) cRIO-9068
Is it possible to move a file to a flash drive? I want to create a file on the cRIO hard drive and then move it to a flash drive. It seems like you can write directly to a flash drive, but I get Error 8 (File permission error) if I try to use the Move file function to move a file between the hard drive of the cRIO and a USB flash drive. Do I need to use something like the WebDAV protocol to do this transfer?
Attached code shows the "move" I am trying to do.
Thanks!
(5,103 Views)
Accepted by topic author Lauren_MSI
I believe this is due to a permissions warning, and has already been found and fixed in the next release. Until then, use the System Exec.vi to move files with the 'move' function when moving files between devices:
mv <filepath1> <filepath2>
in a string command.
Michael P
(3,956 Views)
Attached there's a simple version of the copy.vi that uses system exec. Remember that it's just a draft and there are several improvements you can do (e.g. improve error handling).
hope this helps,
Fabio
Fabio M.
NI
Principal Engineer
(3,956 Views)
