NI Linux Real-Time Discussions
Memory Leak in File Writes?
We have noticed a strange effect in our code on the 9068 that is not present on other cRIO (or Windows) platforms.
It seems some memory is allocated when opening, writing to a file, and closing the file and is never released and if you do this enough you will run out of memory. We created a simple VI that loops through creating files and you can watch in distributed system manager the memory shoot up. The amount of memory allocated is directly related to the size of the data you write to disk. This leak is present for all file writes (TDMS, Binary, DataLog, etc..).
The memory is not released until you actually delete the files. The OS does not report that the LV runtime is consuming the memory.. it's just gone somewhere else. Killing the LV runtime process does not release the memory. The other strange thing is that although it consumes all the memory, it doesn't crash the system, it saturates at 100% but continutes to run.
We are working with an NI AE on this, but I thought I'd ask to see if anyone else has run into this? We are working around this currently by limiting the number of log files and when we hit the limit deleting the oldest file. It deletes the file on disk and also releases the memory associated with that file.
Attached is a simple VI if you deploy to a 9068 and watch in distributes system manager you can see the memory fly up.
Graham
Message 1 of 27
(15,393 Views)
Hi Graham,
Is the program still running just fine?  This could be attributed to the way LabVIEW reports memory usage on the NI Linux Real-Time Operating System.  Linux reports memory usage in a unique manner that is different from other operating sytems.  There is a Knowledgebase article here that I would suggest you take a look at and see if that matches what you are seeing with your application.  If so, you may be able to safely disregard the memory allocation you are seeing and continue as normal.  If you do run into any crashes or memory allocation issues otherwise, then you are going down the right path to work with NI AE.
| Zach J. | Systems Engineer, HIL and Test Cells | National Instruments |
Message 2 of 27
(11,303 Views)
That's correct the program still runs fine. It's too bad that LV reports it this way, if we want to present the memory usage for our users it is a bit disconcerting to see it maxed out. That all makes sense though, thanks for the help.
Graham
Message 3 of 27
(11,303 Views)
Graham,
I think the way memory usage is reported for NI Linux Real-Time targets in LabVIEW is being looked into for the future.  For the current distribution of our NI Linux Real-Time OS that was a feature that did not turn out perfect on the first roll-out.  The NI Linux Real-Time OS is full of great features, but with it being released less than a year ago there are still small components that could be improved to make it that much better.  A lot of our developers love to look through these forums, so posting here was a great idea!  I am in agreement that the article I linked sounds very similar to what you are seeing, but let us know if you do run into any system hangs or crashes due to memory allocation and we will help out!  Have a great day.
Message 4 of 27
(11,303 Views)
We actually implemented a fairly simple workaround for now if anyone else is interested. Most of this information can be easily parsed out of the /proc/meminfo file on the 9068. There are other things that can be pulled from here also. I attached a VI that gives you Free Memory more accurately. This can be easily extended for other parameters just google "/proc/meminfo".
Graham
Message 5 of 27
(11,303 Views)
It looks like you're computing free memory as (MemFree+Buffers+Cached). Yes, that is what the common wisdom of the Internet says you should do; yes, this there are good reasons for doing it that way; no, it is not the correct formula for NI Linux Real-Time 2013, and is likely to overestimate the amount of free memory by a significant amount.
The formula we're using nowadays is:
(Free memory that LabVIEW RT can allocate) = (CommitLimit-Committed_AS)*(31/32) - (VmSize/32) EDIT:
(Free memory that LabVIEW RT can allocate) = (CommitLimit)*(31/32) - (VmSize/32) - Committed_AS
… where CommitLimit and Committed_AS are from /proc/meminfo, and VmSize is from /proc/self/stat.
The rationale behind this formula is a bit obscure, and involves the Linux kernel's heuristics about how much memory a process is allowed to allocate, along with the particular way we are configuring memory overcommit. I can provide go into more detail if you're curious.
In lieu of a DSM that uses this new formula, I've tweaked your VI to use this formula. (And I see that you, too, have also run into issue# 112702. )
Disclaimer: totally unsupported, not well tested, these formulas may change without notice in any future release, yadda yadda yadda. Basically you should be moving back to NI-provided APIs for this stuff as soon as it is practicable to do so, because we really are making an effort to hide this complexity from you. (I like to think so, anyway.)
Fixed an error spotted in the free memory formula; I was underestimating the free memory by Committed_AS/32. Both the formula and the VI have been updated.
