NI Linux Real-Time Discussions
Reply
How to configure regional settings, keyboard, ...
I use a cRio 9030 with a touchescreen (TSM-1012).
  • How can I modify the date and time format ? I want to set them to fr_CH
  • How can I modify the keyboard layout ? I want to use fr_CH.
Any help would be greatly appreciated.
(1,616 Views)
Re: How to configure regional settings, keyboard, ...
Not sure if you are asking about modifying them from a LabVIEW application or settings dialogs. Also not sure if you are asking about a physical keyboard layout (assumed in the reply below) or a touch screen virtual keyboard.
If you just want to manually set them:
  • You can set the timezone in "Measurment & Automation Explorer". See the "Time Settings" tab when you click on a target. There are ways to do this programmatically too.
  • Setting the keyboard layout at the moment is a target only option: look under the "Settings->Keyboard" dialog. You can also do this programmatically via the System Exec vi or from a terminal. For example you can use the 'xfconf-query' utility to see/change the current keyboard layouts:  xfconf-query -c keyboard-layout -p /Default/XkbLayout
You can find more information about the 'xfconf-query' utility here: http://docs.xfce.org/xfce/xfconf/xfconf-query
(1,042 Views)
