NI Linux Real-Time Discussions
FPGA Interface C API for PXI (x86) use NI RT Linux?
Hello, i just started the project with NI RT Linux.
I have a project to work with NI RT Linux on PXI hardware platform using FPGA Module PXI-7951
When reading the document, I see that the FPGA Interface C API supports NI RT Linux on x86 as shown, detailed at page: , but at page it does not support FPGA Interface C API for PXI (x86) using using NI RT Linux
So how should I understand? Can FPGA Interface C API for PXI (x86) use NI RT Linux?
Thank you for reading, I hope you all answer my questions.
(927 Views)
Someone from NI can probably confirm but I suspect that bottom link is just out of date.
PXI used to run Pharlap for their real-time OS which is listed there. But now that is deprecated and they run LinuxRT. I would be surprised if this wasn't supported.
James Mc
CLA and cRIO Fanatic
My writings on LabVIEW Development are at devs.wiresmithtech.com
(826 Views)
Yes, that table is out of date. I'd recommend submitting some site feedback on that page at the very bottom right to flag it to get cleaned up.
~ The wizard formerly known as DerrickB ~
Gradatim Ferociter
(811 Views)
