09-09-2016 03:13 PM
So I'm still sorta looking into getting Wine running on an x64 based controller, and it seems the path to make this work hits many road blocks when it comes to the choice in package management. Other Linux distros aren't as open with their package manageers, but there is more of an eco system with them. Others like apt-get, yum, deb, and dnf just to name a few. So I started looking into how to install some of these other package managers and I figured I'd try apt-get since it seems to be popular.
APT has a pretty useful download and install page here. But running the sh files seems to require the Java runtime engine. So I tried installing the RPM. First I had to install RPM using OPKG then install the RPM but I needed to use the --nodeps because it believed dependencies were missing when it seemed they were already installed. The paths it complained about had files with the exact names. After that the APT installer still wouldn't run with an error:
./jre/bin/java: No such file or directory
But doing Java -version returns what looks like a good install. Instead of running the sh where it was I could extract it using a different Linux machine, then try to run the Jar file itself. This resulted in several exception, and failed dependency errors. Is there other options with package managers? Is there other options with Java? Thanks.
java.awt.HeadlessException:
No X11 DISPLAY variable was set, but this program performed an operation which requires it.
at java.awt.GraphicsEnvironment.checkHeadless(GraphicsEnvironment.java:204)
at java.awt.Window.<init>(Window.java:536)
at java.awt.Frame.<init>(Frame.java:420)
at java.awt.Frame.<init>(Frame.java:385)
at javax.swing.JFrame.<init>(JFrame.java:189)
at com.izforge.izpack.installer.GUIInstaller.loadLangPack(Unknown Source)
at com.izforge.izpack.installer.GUIInstaller.access$000(Unknown Source)
at com.izforge.izpack.installer.GUIInstaller$1.run(Unknown Source)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:301)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:756)
at java.awt.EventQueue.access$500(EventQueue.java:97)
at java.awt.EventQueue$3.run(EventQueue.java:709)
at java.awt.EventQueue$3.run(EventQueue.java:703)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:76)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:726)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:201)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
Can not find optional resource conditions.xml
No specification for conditions found.
RulesEngine.init()
Initializing builtin conditions for packs.
Pack.getCondition(): null for pack APT
No custom langpack available.
java.lang.NullPointerException
at com.izforge.izpack.installer.GUIInstaller.loadGUI(Unknown Source)
at com.izforge.izpack.installer.GUIInstaller.access$100(Unknown Source)
at com.izforge.izpack.installer.GUIInstaller$2.run(Unknown Source)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:311)
Get going with G! - LabVIEW Wiki.
17 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
09-09-2016 05:00 PM
Since the ipk package format is essentially a stripped-down version of the deb package format (dpkg/apt/aptitude/synaptic), you can usually install the .deb directly from opkg. One thing, however, to be aware of is that package names between the .deb and .ipk may differ, so there's a little detective work and playing the part of the package manager involved
09-09-2016 10:14 PM
"... there's a little detective work..."
Specifically checking the listed dependencies and whether or not they're already installed.
09-12-2016 08:18 AM
Oh I have been doing some detective work for sure. Installing a package will complain about all kinds of missing dependencies. Several times it will state missing dependencies for things that are already installed. For things that aren't already installed I'll track down the dependency, and it will claim it has a missing dependency...which is already installed. I've had some success with using the --nodeps to force and install if it thinks dependencies are missing that aren't. Then there are times when I know a dependency is missing, it is not installed, and I can't find it in a compatibile opkg format.
I'm not done trying to track it down, but I did get yum installed. It throws errors with some kind of missing python dependency (which are installed) but I was able to make and make install yum from source.
After installing a whole bunch of stuff:
opkg install packagegroup-core-buildessential
opkg install packagegroup-core-buildessential-dev
opkg install packagegroup-core-python
opkg install packagegroup-core-full-cmdline
opkg install packagegroup-core-perl
I downloaded the tar ball from here. I uncompressed it with "tar zxf file.tar.gz" performed a make, then make install in the directory. Then running yum from bash I get the following, which may indicate a version compatibility issue with python.
There was a problem importing one of the Python modules
required to run yum. The error leading to this problem was:
No module named yum
Please install a package which provides this module, or
verify that the module is installed correctly.
It's possible that the above module doesn't match the
current version of Python, which is:
2.7.9 (default, Jun 8 2016, 23:40:34)
[GCC 4.8.2]
If you cannot solve this problem yourself, please go to
the yum faq at:
http://yum.baseurl.org/wiki/Faq
09-12-2016 04:22 PM
I would certainly recommend avoiding attempting to use two package managers unless you know what you're getting yourself into and can dig yourself out. The niceties that some distros provide for mixing package managers is largely absent from NI LInux RT. That being said, again, if I was in your position I'd try to make opkg work for what you need for installing the .deb file. I would start from a clean format of the controller
