NI Labs Toolkits
Separate Compiled Code for VIs and other files
Mark VIs and other files to Separate Compiled Code tool can be used to mark/unmark a directory hierarchy of VIs and project libraries to separate compiled code from source file. It provides a way to batch convert Files outside the project interface.
System Requirement: LabVIEW 2010 or later
Usage: Place the "SeparateCompiledCode.llb" in your <LabVIEW>/project folder.
After restarting LabVIEW, you will be able to find "Mark VIs Separate Compiled Code..." in your tools menu.
Comments
Trusted Enthusiast
Trusted Enthusiast
This can indeed be very useful!
Kind Regards,
Thierry C - CLA, CTA - Staff R&D Engineer, RF Semiconductor Test - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. Smiley Wink
Member SMcGraw
Member
Please download the latest version.  The first version had a bug where it would only mark VIs but not other file types.
Active Participant warren_scott
Active Participant
broken for files inside .llb's
Member SMcGraw
Member
Thank you for reporting this bug.  I've updated the tool so it now works for files inside .llbs
Member Mike_Diesen
Member
Will this funcationality work with LabVIEW 2015?
Member SMcGraw
Member
Yes, this works with 2015.
Member TeraTech
Member
Kudos on the great tool! I am baffled as to why this has not been incorporated into LabVIEW.
Could someone comment on the usage of the tool?  Should I first clear compiled object cache, run the SeparateCompiledCode tool on my top level project folder, then follow it with a  Mass Compile of that folder?
If I now want to copy this folder to another computer: On the destination computer, first do a clear compiled object cache, dopy the vis over, do Mass Compile on the new vis?
Contributors
