This is an update to NeuroSky LabVIEW Driver Demo: https://decibel.ni.com/content/docs/DOC-19690
I fixed a few issues with the demo. Please follow the original document for driver installation. You can use the latest labview_neurosky_driver-1.1.1.5_vip without installing the old driver.
System/Software Used:
- Windows 7 64-bit
- LabVIEW 2011 SP1
- NeuroSky MindSet device
There are several issue that I am trying to figure out:
- Sometimes the device handle gets lost and the VI would stop. In this case I need to shut down the MindSet, and establish the Bluetooth connection again. Only then I can run the VI again.
- Not sure if it is related to the MindSet audio stream that is received by the set while the VI is running. Need more testing to establish the root cause.
Windows XP 32 bit
Labview 2011 SP1
Neurosky Mindset
When I run NeuroSkyDemoFixed.vi, I get the error message,
"serialPortName could not be opened as a serial communication port for any reason.
Check that the name is a valid COM port on your system."
I am using COM40 which seems to work with other software and mindset. Any help would be appreciated.
Make sure COM40 is not used by other devices. Disconnect the port using the Bluetooth Manager and connect it again, then try the VI.
Let me know if this helps.
That did it. Thanks.
Can I run this Neurosky Lab view demo with mind wave headset ? (please refer the following link)
http://www.mindtecstore.com/index.php/en/mindwave?showall=1#downloads
Any help would be really appreciated. Thank you!
I am not sure, but if you tried, could you let us know how it went?
Thanks!
Hello
I'm trying to use NeuroSky on labview on my laptop with mindweave equipment but everytime I recieve this : Error -10 occured at NeuroSky Driver.lvlib ThinkGear SingleSample Read Raw.vi could someone explain what I'm doing wrong?
Did you mean MindWave? If so, not sure it is going to work since the code was tested on MindSet (which they do not sell anymore).
Is there a Labview driver for neurosky BMD100 ECG chip?
Hello, please help,
NeuroSkyDemoFixed.vi When I run, I get the error message , search Raw.vi read, read Gamma2.vi, Gamma1.vi read, read Beta2.vi , Beta1.vi read, read Alpha2.vi , Alpha1.vi read, read Theta.vi , Read Delta.vi , Values ThinkGear Connect to File.vi , ThinkGear signal Quality.vi , ThikGear SingleSample Red Attention.vi , ThikGear SingleSample Red Meditation.vi , ThikGear Blink Strenght.vi , etc ... ie , all files .vi not found ....
Urgent help!
