Introduction
This USB DAQ Driver is compatible with the NI USB-6008/6009 devices and runs on the Raspberry Pi®. It allows the user to acquire data from an analogue input channel in either a continuous or finite manner, whilst streaming this data to a web service compatible with LabVIEW and Data Dashboard for LabVIEW. The driver is also capable of controlling a user selectable digital line from the Web Service.
Requirements
Installation Instructions
Note: If you are already running a web server on your Raspberry Pi®, you will need to set Lighttpd to run on a port other than 80, edit this in the lighttpd.conf file on the line server.port = 80.
Please note that you will have to change the discovery port when you use Data Dashboard for LabVIEW if this is the case.
Running
Run the programs located in /usr/local/bin/natinst/rpi
, you must run these as root:
a. ./600x – Allows you to select the analogue channel you wish to continuously read from and the digital out line you want to control the output of. This is the demo shown at NIDays UK 2012
Usage: ./600x -c 0 -t 10000 -l 6
-c : Channel Number, 0 indexed that you wish to read from
-t : Timeout in ms, timeout of the device before erroring
-l : Digital line to output on, 1 indexed for Port 0 only
Example: ./600x -c 0 -t 10000 -l 6
Acquire data on channel 0 and link to the digital line 6 on port 0
b. ./aiondemand – Allows you to read a set number of samples on demand and output to the console and web services as requested.
Usage: ./aiondemand -c 0 -s 500 -t 10000 -v -w
-s : Samples to fetch, limited to 500 or less when on demand
-v : Verbose, output to terminal window
-w : WebServices, output to Web Service for Data Dashboard
Example: ./aiondemand -c 0 -s 500 -t 10000 -v -w
Acquire 500 samples on demand on AI channel 0 and output this to Terminal and Web Services
Run Data Dashboard on the iPad and add a new Web Service. Add in the IP Address of your Raspberry Pi® and select port 80 (if you changed the port in the Lighttpd conf file, change it here too)
There is an example Data Dashboard file included here (the one used at NIDays UK 2012).
Raspberry Pi® is a trademark of the Raspberry Pi® Foundation
Sudo sh install.sh runs, but after "Checking Permissions..." I get the syntax error "end of file unexpected (expecting "then")
Any clue what would cause this and how to fix it?
nm... Just opened up the file and ran the commands manually
now I'm getting a Segmentation fault when running the programs
What are the chances this can work with http://www.ni.com/en-us/support/model.usb-6001.html Is this driver open source? Can I make any mods to it if needed?
Would love to get an answer to the question above!
I have followed all the step on my R PI 3
I am using the USB-6009
When rinning the command: ./600x -c 0 -t 10000 -l 6
it returns with
Detected NI USB Devices
Confirm: USB0::0x3923::0x0000::::RAW
Segmentation fault
Can anyone help me get this working.
I followed the step, and succeed. There is some tips for you. I hope that might be helpful.
Firstly, connect USB-6009 to a USB HUB which has extra power. This could solve the problem, which is cause of low current.
Then, make sure the firmware of USB-6009 is NI-DAQmx Base version, generally that would be NI-DAQmx version. The Instruction is as follows: http://digital.ni.com/public.nsf/allkb/1448A8AC665EE0EA8625703F004A4410?OpenDocument
I just got the NI USB-6009 working with an RPi3 under "Stretch". The biggest problem I had was updating the Firmware to NI-DAQmx Base. My Laptop showed the 6009 as NI-DAQmx Base Device, but it did not work, i had to update the firmware (The tools in the linked article did not work [Error 7 if I remember right], but you will find another version of the tool in your installation direction [same name, different size]. With this tool I got the Firmware updated).
Where do I change the Input mode between DIFF and RES? Do i have to set it up at my laptop or are you only able to use on of the modes with the raspberry? Which mode can I use?
And is there any more work done on the driver for the raspberry pi? I am missing an option to set the scan rate and read more channels simultaniously. (I am not really hopefull, since the article was last updated in early 2017).
Thanks and regards!
Can I edit the programs? or Make my own program? Which programming language is? I want to send the continuously read to the serial port or just know where can I take the digital data to use into other code?. Thank you.
I am hoping someone is actually looking at these forums. I am trying to use Raspberry Pi as a master which can control the NI DAQ(NI 6341 USB). Is this still an active thread? Looks like it was from 2012 and updated on 2017. Is this the only documentation that NI Provides for arm based linux platforms(RPi)? I hope someone from NI looks at this and give us some clear direction.
Thank you.
