This library provides a test suite to identify some of the issues that may affect your existing LabVIEW code after upgrading.
Changes may be made to LabVIEW between versions that could affect your code when upgrading. We attempt to document as many of these changes as possible in the LabVIEW Upgrade Notes and in the LabVIEW Known Issues Document. We have developed VI Analyzer Tests to help you determine if your source code might be affected by any changes in LabVIEW, and since the VI Analyzer engine is now included as core part of LabVIEW, anyone can run these tests. We recommend all users carefully examine the LabVIEW Upgrade Notes before upgrading LabVIEW. Some of the tests included are described in the Upgrade Notes, but not every documented issue has a test. The other tests come from issues that were not reported in the Upgrade Notes. Most of these tests are documented as Known Issues in the LabVIEW Known Issues document. We plan to update the tests to include tests for new issues as they are reported (if a test can be written, and if the issue is one that could affect you when upgrading). For information on how to report new issues see the “Where to go for Help” section below.
The tests can only be run in the latest LabVIEW version, and testing the code requires that the VIs be loaded into the current LabVIEW version. This means that to use the tests, you must install the latest LabVIEW version, and your VIs will be loaded and compiled for that version. However, the VIs that you are analyzing are not automatically saved. If you do not wish to upgrade your VIs at the time you run your tests, do not save the VIs in the current version. You will still be able to review the issues without saving the VIs. The attachment Included_Tests_08_01_08.zip contains an HTML table listing the tests that are included in this release.
Where to go for help, and how to provide feedback:
Please decide which statement describes your situation best for instructions on how to contact us.
If you are experiencing an issue in LabVIEW that appears to be new to the current version, or has affected your upgrade from a previous version, and the issue is not documented in the LabVIEW Upgrade Notes or the LabVIEW Known Issues document:
If you have encountered an issue that is affecting your upgrade that has been reported to NI, documented in the Upgrade Notes, or documented in the Known Issues document, and you would like to request a test be made for the issue:
If you can successfully run the VI Analyzer Upgrade Tests, and you would like more information on a specific issue for which a test was written:
If you are having problems installing or using the VI Analyzer Upgrade Tests, have feedback on the process of these VI Analyzer Tests, would like to report a problem executing a specific test, or any other general comments on this project:
