Introduction
The LabVIEW 2009 Upgrade Tests are designed to help you identify some of the issues that may affect your existing code after upgrading to LabVIEW 2009.
Changes to LabVIEW may affect your code when upgrading. We attempt to document these changes in the LabVIEW Upgrade Notes and in the LabVIEW Known Issues. We have also developed these tests to help you determine if your source code might be affected by any changes in LabVIEW.
Requirements
LabVIEW 2009 (these tests must be run in LabVIEW 2009)
Installation
- Download and unzip the attached LabVIEW 2009 Upgrade Tests.zip.
- Run the contained setup.exe.
Chris Bolin
LabVIEW Partner Program, CLA
