NI Labs Toolkits
LabVIEW 2009 Upgrade Tests
Introduction
The LabVIEW 2009 Upgrade Tests are designed to help you identify some of the issues that may affect your existing code after upgrading to LabVIEW 2009.
Changes to LabVIEW may affect your code when upgrading.  We attempt to document these changes in the LabVIEW Upgrade Notes and in the LabVIEW Known Issues.  We have also developed these tests to help you determine if your source code might be affected by any changes in LabVIEW.
Requirements
LabVIEW 2009 (these tests must be run in LabVIEW 2009)
Installation
  1. Download and unzip the attached LabVIEW 2009 Upgrade Tests.zip.
  2. Run the contained setup.exe.
    Chris Bolin
    LabVIEW Partner Program, CLA
    Comments
    Member
    Member
    on
    I think this folder probably should get copied into '<LabVIEW Data>\VI Analyzer Tests\LabVIEW 2009 Upgrade Issues', right?
    NI Employee
    on
    Good catch!  We will have an installer up very soon so you won't have to worry about folders.
    Chris Bolin
    NI Employee
    on
    The updaded installer was just uploaded. 'Hope this solves the problem.
    Natasa
    Member
    Member
    on
    Perfect!
    Contributors
