This utility has been officially released as part of NI MAX / System Configuration 15.0 and later. Any supported NI software configuration can be upgraded to use the latest version of NI System Configuration.
Running the Remote System Discovery Troubleshooting Wizard
- Open Measurement & Automation Explorer (MAX)
- Right-click on the Remote Systems tree
- Select Troubleshoot Remote System Discovery from the right-click menu
Description
Having trouble discovering your networked real-time target through Measurement & Automation Explorer (MAX)? Networked device discovery is a complicated procedure that can be affected by several variables including (but not limited to):
- Software Compatibility - Is your target (hardware) compatible with the software on your computer?
- Firewall Configuration - Is your Windows or third-party firewall blocking the network ports used for discovery?
- Cabling / Port Usage - Are you using an incorrect type of cable or the incorrect network port on your target?
- IP Addressing - Is the IP address used by your target in conflict with the IP addressing scheme of your computer?
- Subnetting - Is the target located on the same subnet as your computer?
This wizard will intelligently guide you through a set of troubleshooting steps specifically designed for your target.
